中华钢结构论坛
近年来冷弯型钢结构方面的部分论文(国外)
htz
积分 421
帖子 193
2004-3-16 19:26    顶部
1. Specification for the Design of Cold-Formed Stainless Steel Structural Members...
the Design of Cold-Formed Stainless Steel Structural Members, SEI ... the Design of Cold-Formed Stainless Steel Structural Members (ASCE ... members may be cold-formed to shape from annealed
http://www.pubs.asce.org/BOOKdisplay.cgi?9991527
2.Bending Behavior of Composite Girders with Cold Formed Steel U Section
Shun-ichi Nakamura,1 P.E., M.ASCE
1Professor, Dept. of Civil Engineering, Tokai Univ., 1117 Kitakaname, Hiratsuka 259-1292, Japan
Bolted Connection Tests of Thin G550 and G300 Sheet Steels
Colin A. Rogers
PhD Res. Student, Dept. of Civ. Engrg., Univ. of Sydney, Sydney, New South Wales 2006, Australia.
4.Ductility of G550 Sheet Steels in Tension
Colin A. Rogers
PhD Res. Student, Dept. of Civ. Engrg., Univ. of Sydney, Australia.
Gregory J. Hancock
BHP Steel Prof. of Steel Struct., Dept. of Civ. Engrg., Univ. of Sydney, Australia
5..  Influence of Bend Radii on Local Buckling in Cold Formed Shapes
Cedric Marsh
J. Struct. Engrg. 123, 1686 (1997)   PDF (224 kB)   GZipped PS   Order
  6.Finite Element Idealization of a Cold-Formed Steel Portal Frame
by James B. P. Lim, (Res. Engr., The Steel Constr. Inst., Silwood Park, Ascot, Berkshire SL5 7QN, United Kingdom) and David A. Nethercot, (Prof., Dept. of Civ. and Envir. Engrg., Imperial Coll., Longon SW7 2BU, United Kingdom. E-mail: d.nethercot@ic.ac.uk)
Journal of Structural Engineering, Vol. 130, No. 1, January 2004, pp. 78-94
    Cold-Formed Steel Channels Subjected to Concentrated Bearing Load
by Ben Young, Member, ASCE, (Asst. Prof., Dept. of Civ. Engrg., Hong Kong Univ. of Sci. and Technol., Clear Water Bay, Kowloon, Hong Kong. E-mail: byoung@us.hk) and Gregory J. Hancock, (BHP Steel Prof. of Steel Structure, Dept. of Civ. Engrg., Univ. of Sydney, New South Wales 2006, Australia)
Journal of Structural Engineering, Vol. 129, No. 8, August 2003, pp. 1003-1010
8.Evaluation of Tensile and Bearing Capacities of Cold-Formed Steel Connections Attached with Pneumatically Driven Pins
by Stuart Werner Baur and Wimal Suaris
9.Experimental Investigation of Cold-Formed Stainless Steel Columns
by Ben Young, Member, ASCE, (Asst. Prof., Dept. of Civ. Engrg., Hong Kong Univ. of Sci. and Technol., Clear Water Bay, Kowloon, Hong Kong. E-mail: byoung@ust.hk) and Yahua Liu, (Postgraduate Res. Student, School of Civ. and Envir. Engrg., Nanyang Technol. Univ., Nanyang Avenue, Singapore 639798)
Journal of Structural Engineering, Vol. 129, No. 2, February 2003, pp. 169-176
10.Local Buckling Tests on Cold-Formed Steel Beams
by Cheng Yu, (Grad. Res. Asst, l306 Latrobe Hall, Johns Hopkins Univ., Baltimore, MD 21218. E-mail: cheng.yu@jhu.edu) and Benjamin W. Schafer, (Asst. Prof., 203 Latrobe Hall, Johns Hopkins Univ., Baltimore, MD 21218. E-mail: schafer@jhu.edu)
Journal of Structural Engineering, Vol. 129, No. 12, December 2003, pp. 1596-1606
  11.  Tests of Cold-Formed Circular Tubular Braces under Cyclic Axial Loading
by Mohamed Elchalakani, (Postgraduate Student, Dept. of Civ. Engrg., Monash Univ., Victoria 3800, Australia), Xiao-Ling Zhao, Member, ASCE, (Prof., Dept. of Civ. Engrg., Monash Univ., Victoria 3800, Australia), and Raphael Grzebieta, (Assoc. Prof., Dept. of Civ. Engrg., Monash Univ., Victoria 3800, Australia)
Journal of Structural Engineering, Vol. 129, No. 4, April 2003, pp. 507-51
12.Column Tests of Cold-Formed Steel Channels with Complex Stiffeners
by Jintang Yan, (Postgrad. Res. Student, School of Civ. [$ Struct. Engrg., Nanyang Technol. Univ., Nanyang Ave., Singapore 639798) and Ben Young, (Asst. Prof., Dept. of Civ. Engrg., Hong Kong Univ. of Sci. and Technol., Clear Water Bay, Kowloon, Hong Kong] formerly, Asst. Prof., School of Civ. & Struct. Engrg., Nanyang Technol. Univ., Nanyang Ave., Singapore 639798)
Journal of Structural Engineering, Vol. 128, No. 6, June 2002, pp. 737-745
  13.  Deflection of Nested Cold-Formed Steel Z-Section Beams
by Ahmad Ali Ghosn, Member, ASCE, (Prin. Proj. Analyst, OMPM/DPP, Kuwait Inst. for Sci. Res., P.O. Box 24885, 13109 Safat, Kuwait)
Journal of Structural Engineering, Vol. 128, No. 11, November 2002, pp. 1423-1428
14.Three Books for Cold-Formed Steel Design
by B. W. Schafer, Member, ASCE, (Asst. Prof., Civ. Engrg., Johns Hopkins Univ., Baltimore, MD 21218)
Journal of Structural Engineering, Vol. 128, No. 11, November 2002, pg. 1490
15.Void-Filled Cold-Formed Rectangular Hollow Section Braces Subjected to Large Deformation Cyclic Axial Loading
by Xiao-Ling Zhao, Member, ASCE, (Prof., Dept. of Civ. Engrg., Monash Univ., Clayton VIC 3168, Australia), Raphael Grzebieta, (Assoc. Prof., Dept. of Civ. Engrg., Monash Univ., Clayton VIC 3168, Australia), and Chen Lee, (Postgrad. Student, Dept. of Civ. Engrg., Monash Univ., Clayton VIC 3168, Australia
16.Axial Strength Determination for Gypsum-Sheathed, Cold-Formed Steel Wall Stud Composite Panels
by Young-ki Lee, (Lect., School of Civ. and Envir. Engrg., Kook-Min Univ., Seoul, Korea) and Thomas H. Miller, Member, ASCE, (Assoc. Prof., Civ., Constr., and Envir. Engrg, Oregon State Univ., Corvallis, OR 97331-2302)
Journal of Structural Engineering, Vol. 127, No. 6, June 2001, pp. 608-615
18.Compression Tests on Cold-Formed Angles Loaded Parallel with a Leg
by D. Popovic, (Software Engr., AAO, Eastwood NSW 2121, Australia), G. J. Hancock, (Prof., Dept. of Civ. Engrg., Univ. of Sydney, NSW 2006, Australia), and K. J. R. Rasmussen, (Assoc. Prof., Dept. of Civ. Engrg., Univ. of Sydney, NSW 2006, Australia)
Journal of Structural Engineering, Vol. 127, No. 6, June 2001, pp. 600-607
19.Design of Cold-formed Channels Subjected to Web Crippling
by Ben Young, (Asst. Prof., School of Civ. and Struct. Engrg., Nanyang Technol. Univ., Nanyang Ave., Singapore 639798) and Gregory J. Hancock, (BHP Steel Prof. of Steel Struct., Dept. of Civ. Engrg., Univ. of Sydney, New South Wales 2006, Australia)
Journal of Structural Engineering, Vol. 127, No. 10, October 2001, pp. 1137-1144
20.Limiting Heights for Gypsum-Sheathed, Cold-Formed Steel Wall Studs
by Young-Ki Lee, (Lect., School of Civ. Engrg., Kook-Min Univ., Seoul, Korea) and Thomas H. Miller, Member, ASCE, (Assoc. Prof. of Civ., Constr., and Envir. Engrg., Oregon State Univ., Corvallis, OR 97331-2302)
Practice Periodical on Structural Design and Construction, Vol. 6, No. 2, May 2001, pp. 83-89
21.Yield Moment of Cold-Formed Steel Beams under Different Strain Rates
by Chi-Ling Pan, Assoc. Member, ASCE, (Assoc. Prof., Dept. of Constr. Engrg., Chaoyang Univ. of Tech., 168 Gifeng E. Rd., Wufeng, Taichung County, Taiwan) and Wei-Wen Yu, Fellow, ASCE, (Curators’ Prof. Emeritus, Dept. of Civ. Engrg., Univ. of Missouri-Rolla, Rolla, MO 65401)
Journal of Structural Engineering, Vol. 127, No. 3, March 2001, pp. 264-270
22.Global Optimum Design of Cold-Formed Steel I-Shape Beams
by Asim Karim, (Grad. Res. Assoc., Dept. of Civ. and Envir. Engrg. and Geodetic Sci., Ohio State Univ., Columbus, OH 43210) and Hojjat Adeli, (Prof., Dept. of Civ. and Envir. Engrg. and Geodetic Sci., Ohio State Univ., 470 Hitchcock Hall, 2070 Neil Ave., Columbus, OH)
Practice Periodical on Structural Design and Construction, Vol. 5, No. 2, May 2000, pp.
23.Tests to Examine Plastic Behavior of Knee Joints in Cold-Formed RHS
by Tim Wilkinson, (Lect., Dept. of Civ. Engrg., Univ. of Sydney, Sydney, 2006, Australia) and Gregory J. Hancock, (BHP Steel Prof. of Steel Struct., Dept. of Civ. Engrg., Univ. of Sydney, Sydney, 2006, Australia)
Journal of Structural Engineering, Vol. 126, No. 3, March 2000, pp. 297-305
24.Bending and Torsion of Cold-Formed Channel Beams
by B. M. Put, (Res. Student, Dept. of Civ. Engrg., Univ. of Sydney, Sydney, New South Wales 2006, Australia), Y.-L. Pi, (Sr. Res. Assoc., Dept. of Civ. Engrg., Univ. of Sydney, Sydney, New South Wales 2006, Australia), and N. S. Trahair, Member, ASCE, (Prof., Dept. of Civ. Engrg., Univ. of Sydney, Sydney, New South Wales 2006, Australia)
Journal of Structural Engineering, Vol. 125, No. 5, May 1999, pp. 540-546
25.Biaxial Bending of Cold-Formed Z-Beams
by Bogdan M. Put, (Res. Student, Dept. of Civ. Engrg., Univ. of Sydney, NSW 2006, Australia), Yong-Lin Pi, (Sr. Res. Assoc., Dept. of Civ. Engrg., Univ. of Sydney, NSW, Australia), and N. S. Trahair, (Emeritus Prof. of Civ. Engrg., Univ. of Sydney, NSW, Australia)
Journal of Structural Engineering, Vol. 125, No. 11, November 1999, pp. 1284-1290
   26. Global Optimum Design of Cold-Formed Steel Z-Shape Beams
by Asim Karim, (Grad. Res. Assoc., Dept. of Civ. and Envir. Engrg. and Geodetic Sci., Ohio State Univ., Columbus, OH 43210) and Hojjat Adeli, (Prof., Dept. of Civ. and Envir. Engrg. and Geogetic Sci., Ohio State Univ., 470 Hitchcock Hall, 2070 Neil Ave., Columbus, OH)
Practice Periodical on Structural Design and Construction, Vol. 4, No. 1, February 1999, pp. 17-20
27.Lateral Buckling Tests on Cold-Formed Channel Beams
by Bogdan M. Put, (Res. Student, Dept. of Civ. Engrg., Univ. of Sydney, NSW, 2006, Australia), Yong-Lin Pi, (Sr. Res. Assoc., Dept. of Civ. Engrg., Univ. of Sydney, NSW, 2006, Australia), and N. S. Trahair, Member, ASCE, (Prof. of Civ. Engrg., Univ. of Sydney, NSW, 2006, Australia)
Journal of Structural Engineering, Vol. 125, No. 5, May 1999, pp. 532-539
28.Lateral Buckling Tests on Cold-formed Z-Beams
Journal of Structural Engineering, Vol. 125, No. 11, November 1999, pp. 1277-1283
   29..Laterally Braced Cold-Formed Steel Flexural Members with Edge Stiffened Flanges
by B. W. Schafer, Member, ASCE, (Sr. Engr., Simpson Gumpertz [$ Heger, Inc., 297 Broadway Ave., Arlington, MA 02174) and T. Pek&ouml]z, Member, ASCE, (Prof., Cornell Univ., 220 Hollister Hall, Ithaca, NY 14853)
Journal of Structural Engineering, Vol. 125, No. 2, February 1999, pp. 118-127
30.Analysis and Design Assumptions for Continuous Cold-Formed Purlins
by Howard I. Epstein, (Prof. and Head, Dept. of Civ. and Envir. Engrg., Univ. of Connecticut, Storrs, CT 06269), Erling Murtha-Smith, (Assoc. Dean, School of Engrg., Univ. of Connecticut, Storrs, CT), and Jason D. Mitchell, (Grad. Res. Asst., Dept. of Civ. and Envir. Engrg., Univ. of Connecticut, Storrs, CT)
Practice Periodical on Structural Design and Construction, Vol. 3, No. 2, May 1998, pp. 60-67
31.Axial Fatigue Performance of Cold-Formed Steel Sections
by Sherif K. Hassan, (Asst. Prof., Dept. of Civ. Engrg., Struct. Div., Ain Shams Univ., Cairo, Egypt), D. Polyzois, (Prof., Dept. of Civ. and Geological Engrg., Univ. of Manitoba, Winnipeg, MB, R3T 5V6, Canada), and G. Morris, (Prof., Dept. of Civ. and Geological Engrg., Univ. of Manitoba, Winnipeg, MB, R3T 5V6, Canada)
Journal of Structural Engineering, Vol. 124, No. 2, February 1998, pp. 149-157
32.Cold-Formed Steel Members with Multiple Longitudinal Intermediate Stiffeners
by B. W. Schafer, Member, ASCE, (Instructor and Postdoctoral Res. Assoc., Cornell Univ., 419 Hollister Hall, Ithaca, NY 14853) and T. Pek[$ouml]z, Member, ASCE, (Prof., Cornell Univ., 220 Hollister Hall, Ithaca, NY)
Journal of Structural Engineering, Vol. 124, No. 10, October 1998, pp. 1175-1181
33.Lateral Buckling Strengths of Cold-Formed Channel Section Beams
by Yong-Lin Pi, (Sr. Res. Assoc., Dept. of Civ. Engrg., Univ. of Sydney, NSW, 2006, Australia), B. M. Put, (Res. Student, Dept. of Civ. Engrg., Univ. of Sydney, NSW, 2006, Australia), and N. S. Trahair, Member, ASCE, (Challis Prof., Dept. of Civ. Engrg., Univ. of Sydney, NSW, 2006, Australia)
Journal of Structural Engineering, Vol. 124, No. 10, October 1998, pp. 1182-1191
34.Tests to Examine Compact Web Slenderness of Cold-Formed RHS
by Tim Wilkinson, (PhD Res. Student, Dept. of Civ. Engrg., Univ. of Sydney, Sydney, 2006, Australia) and Gregory J. Hancock, (BHP Steel Prof. of Steel Struct., Dept. of Civ. Engrg., Univ. of Sydney, Sydney, 2006, Australia)
Journal of Structural Engineering, Vol. 124, No. 10, October 1998, pp. 1166-1174
35.Advanced Connection Techniques for Cold-Formed Steel Structures
by R. F. Pedreschi, (Sr. Lect., Dept. of Arch., Univ. of Edinburgh, 20 Chambers St., Edinburgh, EH11JZ, Scotland), B. P. Sinha, (Reader, Dept. of Civ. Engrg., Univ. of Edinburgh, Kings Build., Mayfield Rd., Edinburgh, Scotland), and R. Davies, (Res. Assoc., Dept. of Arch., Univ. of Edinburgh, 20 Chambers St., Edinburgh, EH11JZ, Scotland)
Journal of Structural Engineering, Vol. 123, No. 2, February 1997, pp. 138-144
36.Influence of Bend Radii on Local Buckling in Cold Formed Shapes
by Cedric Marsh, Member, ASCE, (Prof. Emeritus, Ctr. for Bldg. Studies, Concordia Univ., 1455 de Maisonneuve Blvd., Montreal, Quebec, H3Y 3G9, Canada)
Journal of Structural Engineering, Vol. 123, No. 12, December 1997, pp. 1686-1689
37.Material Properties Models for Analysis of Cold-Formed Steel Members
by Nabil Abdel-Rahman, (PhD Candidate, Dept. of Civ. Engrg., McMaster Univ., Hamilton, Ontario, Canada L8S 4L7) and K. S. Sivakumaran, (Assoc. Prof., Dpt. of Civ. Engrg., McMaster Univ., Hamilton, Ontario, Canada L8S 4L7)
Journal of Structural Engineering, Vol. 123, No. 9, September 1997, pp. 1135-1143
39.Neural Network Model for Optimization of Cold-Formed Steel Beams
by Hojjat Adeli, (Prof., Dept. of Civ. and Envir. Engrg. and Geodetic Sci., The Ohio State Univ., 470 Hitchcock Hall, 2070 Neil Ave., Columbus, OH 43210) and Asim Karim, (Grad. Res. Assoc., Dept. of Civ. and Envir. Engrg. and Geodetic Sci., The Ohio State Univ., 470 Hitchcock Hall, 2070 Neil Ave., Columbus, OH)
Journal of Structural Engineering, Vol. 123, No. 11, November 1997, pp. 1535-1543
40.    Study on Composite Panels Consisting of Cold-Formed Steel Channels and Plywood with Self-Drilling Screws
by Koji Hanya, Ryoichi Kanno, and Yoshimichi Kawai
pp. 428-432
41.Behavior of Cold-Formed SHS Beam-Columns
by Raef M. Sully, (PhD Res. Student, School of Civ. and Min. Engrg., The Univ. of Sydney, Australia.) and Gregory J. Hancock, (BHP Steel Prof. of Steel Struct., School of Civ. and Min. Engrg., The University of Sydney, Australia.)
Journal of Structural Engineering, Vol. 122, No. 3, March 1996, pp. 326-336
42.Effect of Temperature and Galvanization on Cold-Formed Steel
by A. B. Abdel-Rahim, (PhD Candidate, Dept. of Civ. and Geological Engrg., Univ. of Manitoba, Winnipeg, MB, CANADA, R3T 2N2) and D. Polyzois, (Prof., Dept. of Civ. and Geological Engrg., Univ. of Manitoba, Winnipeg, MB, CANADA, R3T 2N2)
Journal of Materials in Civil Engineering, Vol. 8, No. 3, August 1996, pp. 114-122
43.Finite Element Computer Models for Analysis of Cold-Formed Steel Members
by K. S. Sivakumaran and Nabil Abdel-Rahman
pp. 690-696
44.Load Capacity of Nested, Laterally Braced, Cold-Formed Steel Z-Section Beams
by Ahmad A. Ghosn, (C.E., Prin. Proj. Analyst, OBD/DPP, Kuwait Inst. for Scientific Res., P.O. Box 24885, 13109 Safat, Kuwait) and Ralph R. Sinno, Fellow, ASCE, (Prof., Civ. Engrg. Dept., Mississippi State Univ., Mississippi State, MS)
Journal of Structural Engineering, Vol. 122, No. 8, August 1996, pp. 968-971
45.Butt Welds and Transverse Fillet Welds in Thin Cold-Formed RHS Members
by Xiao-Ling Zhao, Member, ASCE, (Lect., Dept. of Civ. Engrg., Monash Univ., Clayton, Melbourne, VIC 3168, Australia; formerly, ARC Res. Assoc., School of Civ. and Min. Engrg., Univ. of Sydney, NSW 2006, Australia) and Gregory J. Hancock, (BHP Steel Prof. of Steel Struct., School of Civ. and Min. Engrg., Univ. of Sydney, NSW 2006, Australia)
Journal of Structural Engineering, Vol. 121, No. 11, November 1995, pp. 1674-16
46.Lateral-Buckling Tests of Cold-Formed RHS Beams
by Xiao-Ling Zhao, Member, ASCE, (Lect., Dept. of Civ. Engrg., Monash Univ., Clayton, Melbourne, VIC 3168, Australia; formerly, ARC Res. Assoc., School of Civ. and Min. Engrg., Univ. of Sydney, NSW 2006, Australia), Gregory J. Hancock, (BHP Steel Prof. of Steel Struct., School of Civ. and Min. Engrg., Univ. of Sydney, NSW 2006, Australia), and Nicholas S. Trahair, Member, ASCE, (Challis Prof. of Civ. Engrg., School of Civ. and Min. Engrg., Univ. of Sydney, NSW 2006, Australia)
Journal of Structural Engineering, Vol. 121, No. 11, November 1995, pp. 1565-157
47.Longitudinal Fillet Welds in Thin Cold-Formed RHS Members
Journal of Structural Engineering, Vol. 121, No. 11, November 1995, pp. 1683-1690
48.    Behavior of Gypsum-Sheathed Cold-Formed Steel Wall Studs
by Thomas H. Miller, Assoc. Member, ASCE, (Asst. Prof., Dept. of Civ. Engrg., Oregon State Univ., Corvallis, OR 97331; formerly, Res. Asst., School of Civ. and Envir. Engrg., Cornell Univ., Ithaca, NY 14853) and Teoman Pekoz, Member, ASCE, (Prof., School of Civ. and Envir. Engrg., Cornell Univ., Ithaca, NY)
Journal of Structural Engineering, Vol. 120, No. 5, May 1994, pp. 1644-1650
49.Design Strengths of Cold-Formed Channels in Bending and Torsion
by K. T. Kavanagh, (Sr. Lect., Dept. of Civ. Engrg., Univ. of Western Australia, Nedlands, 6009 Western Australia) and D. S. Ellifritt, Member, ASCE, (Crom Prof. of Struct. Des., Univ. of Florida, Gainesville, FL 32611)
Journal of Structural Engineering, Vol. 120, No. 5, May 1994, pp. 1599-1607
50.Analysis and Computation
(Proceedings of the Eleventh Conference (formerly Electronic Computation Conference) held in conjunction with ASCE Structures Congress ’94 and IASS International Symposium ’94, Atlanta, Georgia, April 24-28, 1994)
htz
积分 421
帖子 193
2004-12-3 14:39    顶部
ASCE Conference Proceedings(会议论文)
1。Cold-Formed Steel Member Cross-Section Shape Optimization by Knowledge-Based Global Optimization Method
H. Liu, B. W. Schafer, and T. Igusa
ASCE Conf. Proc. 137, 150 (2004)
343099-Cold-FormedSteelMemberCross-SectionShapeOptimizationbyKnowledge-BasedGlobalOptimizationMethod.pdf ( 362.24 K) 下载次数 80
htz
积分 421
帖子 193
2004-12-3 14:44    顶部
2。Evaluation of Tensile and Bearing Capacities of Cold-Formed Steel Connections Attached with Pneumatically Driven Pins
ASCE Conf. Proc. 116, 42 (2003)
343105-EvaluationofTensileandBearingCapacitiesofCold-FormedSteelConnectionsAttachedwithPneumaticallyDrivenPins.pdf ( 579.83 K) 下载次数 60
htz
积分 421
帖子 193
2004-12-3 14:45    顶部
3。Estimation of Required Restraint Forces: Z-purlin Supported, Sloped Roofs Under Gravity Loads
Michael C. Neubert and Thomas M. Murray
ASCE Conf. Proc. 103, 134 (2000)
343106-EstimationofRequiredRestraintForces-Z-purlinSupportedSlopedRoofsUnderGravityLoads.pdf ( 198.18 K) 下载次数 97
htz
积分 421
帖子 193
2004-12-3 14:52    顶部
4。Explosion-Resistant Steel Stud Wall System
H. A. Salim and P. T. Townsend
ASCE Conf. Proc. 137, 20 (2004)
343114-Explosion-ResistantSteelStudWallSystem.pdf ( 858.61 K) 下载次数 94
htz
积分 421
帖子 193
2004-12-3 14:57    顶部
部分杂志(ASCE)等上的文章
1。Neural Network Model for Optimization of Cold-Formed Steel Beams
343123-NeuralNetworkModelforOptimizationofCold-FormedSteelBeams.pdf ( 806.54 K) 下载次数 101
htz
积分 421
帖子 193
2004-12-3 14:58    顶部
2。Analysis and Design Assumptions for Continuous Cold-Formed Purlins
343125-AnalysisandDesignAssumptionsforContinuousCold-FormedPurlins.pdf ( 801.92 K) 下载次数 87
htz
积分 421
帖子 193
2004-12-3 14:59    顶部
3。Tests and Design of Fixed-Ended Cold-Formed Steel Plain Angle Columns
343126-TestsandDesignofFixed-EndedCold-FormedSteelPlainAngleColumns.pdf ( 155.27 K) 下载次数 89
htz
积分 421
帖子 193
2004-12-3 15:00    顶部
4。Design of Cold-Formed Steel Channel Columns with Complex Edge Stiffeners by Direct Strength Method
343128-DesignofCold-FormedSteelChannelColumnswithComplexEdgeStiffenersbyDirectStrengthMethod.pdf ( 92.82 K) 下载次数 95
htz
积分 421
帖子 193
2004-12-3 15:00    顶部
5。Cold-Formed Steel Member Cross-Section Shape Optimization by Knowledge-Based Global Optimization Method
343129-Cold-FormedSteelMemberCross-SectionShapeOptimizationbyKnowledge-BasedGlobalOptimizationMethod.pdf ( 362.24 K) 下载次数 38
htz
积分 421
帖子 193
2004-12-3 15:06    顶部
6。Compression Tests of Channels with Inclined Simple Edge Stiffeners
343135-CompressionTestsofChannelswithInclinedSimpleEdgeStiffeners.pdf ( 326.25 K) 下载次数 69
htz
积分 421
帖子 193
2004-12-3 15:08    顶部
7。Axial Compression Tests of Cold-Formed Angles
343136-AxialCompressionTestsofCold-FormedAngles.pdf ( 258.54 K) 下载次数 77
htz
积分 421
帖子 193
2004-12-3 15:09    顶部
8。Estimation of Required Restraint Forces-Z-purlin Supported, Sloped Roofs Under Gravity Loads
343137-EstimationofRequiredRestraintForces-Z-purlinSupportedSlopedRoofsUnderGravityLoads.pdf ( 198.18 K) 下载次数 73
htz
积分 421
帖子 193
2004-12-3 15:10    顶部
9。Web Crippling Strength of Steel Deck Subjected to End One Flange Loading
343139-WebCripplingStrengthofSteelDeckSubjectedtoEndOneFlangeLoading.pdf ( 456.21 K) 下载次数 67
htz
积分 421
帖子 193
2004-12-3 15:11    顶部
10。Finite Element Idealization of a Cold-Formed Steel Portal Frame
343141-FiniteElementIdealizationofaCold-FormedSteelPortalFrame.pdf ( 643.04 K) 下载次数 82
htz
积分 421
帖子 193
2004-12-3 15:14    顶部
11。Channel Columns Undergoing Local, Distortional, and Overall Buckling
343143-ChannelColumnsUndergoingLocalDistortionalandOverallBuckling.pdf ( 273.77 K) 下载次数 79
小郭
积分 8
帖子 16
2005-8-22 10:56    顶部
能粘一下下面六篇文章吗?
1Finite Element Idealization of a Cold-Formed Steel Portal Frame
2imental Investigation of Cold-Formed Stainless Steel Columns
3Void-Filled Cold-Formed Rectangular Hollow Section Braces Subjected to LargeDeformation Cyclic Axial Loading
4Tests to Examine Compact Web Slenderness of Cold-Formed RHS
5Behavior of Cold-Formed SHS Beam-Columns
6Finite Element Computer Models for Analysis of Cold-Formed Steel Members
anatoli
积分 246
帖子 159
2007-6-24 15:54    顶部
发几篇2006, 2007的吧。
Experimental and numerical investigations of cold-formed stainless steel tubular sections subjected to concentrated bearing load
728099-Experimentalandnumericalinvestigationsofcold-formedstainlesssteeltubularsectionssubjectedtoconcentratedbearingload.rar ( 751.46 K) 下载次数 47
anatoli
积分 246
帖子 159
2007-6-24 15:56    顶部
Cold-Formed Stainless Steel Sections Subjected to Web Crippling
728100-Cold-FormedStainlessSteelSectionsSubjectedtoWebCrippling.rar ( 188.82 K) 下载次数 76
anatoli
积分 246
帖子 159
2007-6-24 15:58    顶部
Distortional Buckling of Cold-Formed Stainless Steel Sections Experimental Investigation
728101-DistortionalBucklingofCold-FormedStainlessSteelSectionsExperimentalInvestigation.rar ( 315.3 K) 下载次数 81
anatoli
积分 246
帖子 159
2007-6-24 16:01    顶部
Finite-Element Simulation and Design of Cold-Formed Steel Channels Subjected to Web Crippling
728104-Finite-ElementSimulationandDesignofCold-FormedSteelChannelsSubjectedtoWebCrippling.rar ( 265.51 K) 下载次数 79
anatoli
积分 246
帖子 159
2007-6-24 16:02    顶部
Distortional Buckling of Cold-Formed Steel Members
728106-DistortionalBucklingofCold-FormedSteelMembers.rar ( 116.92 K) 下载次数 80
anatoli
积分 246
帖子 159
2007-6-24 16:09    顶部
Predicting the Shear Strength of Mechanical Clinching in Cold-Formed Steel Structures
728109-PredictingtheShearStrengthofMechanicalClinchinginCold-FormedSteelStructures.rar ( 455.12 K) 下载次数 62
anatoli
积分 246
帖子 159
2007-6-24 16:10    顶部
Behavior of Complex Hat Shapes Used as Truss Chord Members
728110-BehaviorofComplexHatShapesUsedasTrussChordMembers.rar ( 282.55 K) 下载次数 72
anatoli
积分 246
帖子 159
2007-6-24 16:12    顶部
Experimental Capacity Assessment of Cold-Formed Boxed Stud and C Stud Wall Systems Used in Australian Residential Construction
728111-ExperimentalCapacityAssessmentofCold-FormedBoxedStudandCStudWallSystemsUsedinAustralianResidentialConstruction.rar ( 202.63 K) 下载次数 44
yt221
积分 20
帖子 9
2011-3-15 18:50    顶部
我收集到一些关于冷弯型钢方面的文章。有的文章老了点,但考虑到目前冷弯钢结构在国内还是在发展中,也许这文章还有一些参考价值。我是按研究的方面分类,有的文章也许和楼上的有重复,望能见谅。这一部分联接方面的文章。
[LGS Connection] Journal Papers for LGS Connection_okok.doc ( 46.5 K) 下载次数 46
yt221
积分 20
帖子 9
2011-3-16 06:11    顶部
这部分是关于横截面优化的文章
[Section Optimisation] Journal Papers for LGS Section Optimisation_okok.doc ( 36.5 K) 下载次数 35
lo583715074ve
积分 0
帖子 1
2011-3-17 11:26    顶部
老师,好东西啊,辛苦列~~
彪悍的人生不需要解释。。。。
yt221
积分 20
帖子 9
2011-3-17 18:19    顶部
这一部分是关于有限元方面的文章
[LGL FEM] Journal Papers for LGS FEM_okok.doc ( 32 K) 下载次数 48
yt221
积分 20
帖子 9
2011-3-17 18:22    顶部
这一部分是关于轻钢龙骨方面的文章
[Wall Stud] Journal Papers for LGS Wall Stud_okok.doc ( 39.5 K) 下载次数 60
上海市通信管理局
