由于写论文要用,急需下列英文文献,查了好多地方都查不到,不知哪位朋友能不能上传一下,或发到我的邮箱:
flyxy121@163.com,非常感谢!
[1] Szlendak.J.,Brodka.J.,Strengthening of T moment of RHS Joints[J].Proc.Instn.Civ.Engrs,Part2, 1985, 79: 717-727.
[2] Fessler.H., M ockford,P.B., etc..al " Parametric equations for the flexibility matrices of single brace tubular joints in offshore structures"[J].Proc.Instn Civ.Engrs,Part2,1986,81,Dec.:675-696.
[3] Fessler.H.,Mockford,P.B., etc..al“Parametric equations for the flexibility matrices of multi-brace tubular joints in offshore structures”[J]. Proc.lnstn Civ.Engrs,Part2,1986,81,Dec.:659-673.
[4] Fessler,H.,Hassell,W.,Hyde,T.H..“A Model Technique for Bending Strength of Tubular Joints”[J].Journal of Strain Analysis,1992,27(4):197-209.
[5] Yang Lixian,Chen Ticyun.“Local flexibility behavior of tubular joints and its effect on global analysis of tubular structures”[J]. China Ocean E- ngineering,1990,4(4):371-384.
[6] Efthymiou M.Local rotational stiffness of unstiffened tubular joints[J].KSEPL Report RKER 85.199.1985.
[15] Romeiyn,A.,etc..al.“The flexibility of uniplanar and multiplanar joints made of circular hollowsections”.Proc.1st'ISOPE'91,Edinburgh,UK,1991:67 -76.
[7] Ueda,Y.,Rashed,S.M.H.,etc.al“An improved joint model and equations for flexibility of tubular joints”[J].Journal of Offshore Mechanics and Arctic Engineering,1990,112:157-168.
[8] Ueda,Y.,Rashed,S.M.H.,etc..al“Flexibility and yield strength of joints in analysis of tubular offshore structures”.Fifth OMAE Symposium,Tokyo,Japan,1986.
[9] Ure,A.,Grundy,P.,etc..al“Flexibility coefficients of tubular connections”[J].Tubular Structures V,London,1993:519-526.
[10] Hyde,T.H.,Leen,S.B..“Prediction of elastic-plastic displacement of tubular joints under combined loading using an energy-based approach”[J].Journal of Strain Analysis,1997,32(6):435-453.
[11] Leen,S.B.,Hyde,T.H..“On the prediction of elastic-plastic generalized load-displacement responses for tubular joints”[J].Journal of Strain Analysis,2000,35(3):205-219.
[12] D.T.Wright.Membranc Forces and Buckling in Reticulated Shells[J].Journal of StructuralDiv., ASCE,1965,91(ST1).
[13] K.P.Buchert.Shell and Shell-like Structure[J].Guide to Stability Design Criteria for Metal Structure,1976.
[14] del.F.F.Pozo,del.V.F.Pozo.Buckling of Ribbed Spherical Shells.Proc.IASS Congress,Madrid,1979.
[15] P.Sharifi,E.P.Popov.Nonliner Buckling Analysis of Sandwich Arches[J].J.Eng.Mech.Div.,1976,10:39-58.
[16] J.L.Batoz,G.Dhatt.Incremental Displacement Algorithm for Nonlinear Problems[J].
Int.J.Num.Meth.Eng.,1979,14:1262-1266.
[17] E.Riks.An Incremental Approach to the Solution of Snapping and Buckling Problems[J].J.Solids Structures,1979,5:529-551.
[18] M.A.Crisfield.An Are-Length Method Including Line Searches and Accelerations[J].
Int.J.Num.Mech.Eng.,1983,19:1269-1289.
[19] E.Ramn.Strategies for Tracing the Nonlinear Response Near Limit Points[J].Nonlinear Finite Element Analysis in Structural Mechanics,1981.
[20] D Dubina.Computation models and numerical solution procedures for nonlinear of single layer lattice shells[J].Int.J.Space Structures,1993,8 (3):321-2333.
[21] IM Kani,R E Mc Connel,T See.The analysis and testing of a single layer,shallow braced dome.3rd International Conference on Space Structures[C],1984:613-2618.
[22] T See,R E Mc Connel.Large displacement elastic buckling of space structures[J].J.Struct.Engng,1986,112(5):1052-21069.
[23] IM Kani,R E Mc Connel.Collapse and post-collapse analysis of shallow lattice domes.Proceeding of the IASS Symposium on Membrane Structures and Space Frames[C],1986,3:105-112.
[24] C Borri,P Spineli.Buckling and post-buckling behavior of single reticulated shells effected by random imperfection[J].Comput.Struct,1988,30(4):937-943.
[25] C.A.Schenk,G.I.Schueller.Buckling analysis of cylindrical shells with random geometric imperfections[J].International Journal of Non-Linear Mechanics,2003,38:1119-1132.
[26] A.Tabiei and G.Simitses.Imperfection sensitivity of shear deformable moderately thick laminated cylindrical shells[J].Computers and structures.1997,62:165-174.
[27] A.H.Heinen,J.Biillesbach.On the influence of geometric imperfections on the stability and vibration of thin- walled shell structures[J].International Journal of Non-Linear Mechanics,2002,37:921–935.
[28] Shiro Kato,Itaru Mutoh,Masaaki Shomura.Collapse of semi-rigidly jointed reticulated domes with initial geometric imperfections[J].Constructional steel research,1998,48:145-168.
[29] Alfonso E.Lopez,Gerald K.Orrison.The effect of joint stiffness on the buckling behavior of reticulated dome structures.Asia-Pacific Conference on shell and Spatial Structures,CCESIASS[C].May 21-25,1996,Beijing.
