我们一起来收集膜结构的外文资料吧!
雾里看花
积分 167
帖子 105
2002-12-27 10:14    顶部
EI上检索到膜结构方面的资料,希望能获得这些文章的热心人帮忙上传
DIALOG No: 05267698  EI Monthly No: EIP99044631737
Title: Cutting pattern generation for tent type structures represented by minimum surfaces
Author: Popov, V.
Corporate Source: SeaTech Ltd, Nizny Novgorod, Russia
Source: Transactions of the Canadian Society for Mechanical Engineering v 22 n 4A 1998. p 369-377
Publication Year: 1998
CODEN: TCMEAP  ISSN: 0315-8977
Language: English
Document Type: JA;(Journal Article)  Treatment Code: T;(Theoretical)
Abstract: The paper is a sequel in a set of papers dealing with the development of the Stretched Grid Method (SGM) to minimize surfaces and other related problems.Now we focus on the generation of the cutting patterns for fabric structures with predetermined forms. Based on equi-areal of surface mapping onto the plane area the basic condition results in a formulation of a system of non-linear equations.The simple iteration procedure for cutting patterns generated is used and explained. The efficiency of the approach is demonstrated with examples of surfaces with single and double-curvature that can be simply unfolded or flattened.(Author abstract) 5 Refs.
Descriptors: *Fabrics;Nonlinear equations;Mathematical models;Iterative methods
Identifiers: Cutting patterns; Stretched grid method (SGM);Surface mapping
819.4 (Fiber Products);921.6 (Numerical Methods)
819 (Textile [$ Fiber Technology)]921 (Applied Mathematics)
End of record 1
DIALOG No: 06116482  EI Monthly No: EIP02357062842
Title: Computer aided texture alignment of Japanese kimono
Author: Sano, Tetsuya;Yamamoto, Hideki
Corporate Source: Faculty of Education Okayama University, Okayama, 700-8530, Japan
Conference Title: 19th IEEE Instrumentation and Measurement Technology Conference
Conference Location: Anchorage, AK, United States  Conference Date: 20020521-20020523
Conference Sponsor: IEEE
Source: Conference Record - IEEE Instrumentation and Measurement Technology Conference v 1 2002. p 491-496 (IEEE cat n 00ch37276)
Publication Year: 2002
CODEN: CRIIE7
Language: English
Conference Number: 59419
Document Type: CA;(Conference Article)  Treatment Code: T;(Theoretical)
Abstract: A yukata is a type of traditional Japanese clothing.An alignment of its texture pattern is an important factor of the yukata design. In the traditional design of the yukata, the calculation of the size, texture alignment and the development of the cutting pattern are manually performed. There are traditional rules for the texture alignment.Especially, the texture alignment depends on the experience and intuition of the skilled person.We have developed a CAD system for Japanese kimono.In this paper, we describe about methods for automatic texture alignment.At first, image processing algorithms to detect the texture pattern in the kimono cloth are developed. Secondarily, methods of the texture alignment based on the traditional rules are developed.Finally, image processing algorithms for the texture alignment based on the traditional rules are proposed.By using this CAD system, designers can easily tailor the yukata regardless of their skill.7 Refs.
Descriptors: *Computer aided design;Textures;Pattern recognition; Algorithms;Computer simulation
Identifiers: Japanese kimono;Computer aided texture alignment;Yukata
723.5 (Computer Applications);933.1 (Crystalline Solids)
723 (Computer Software, Data Handling [$ Applications)]933 (Solid State Physics)
End of record 1
DIALOG No: 06024967  EI Monthly No: EIP02116889229
Title: An algorithm for the determination of optimal cutting patterns
Author: Schilling, Gordian;Georgiadis, Michael C.
Corporate Source: Centre for Res. and Tech - Hellas Chemical Process Eng. Res. Inst., Thessaloniki, Thermi 57001, Greece
Source: Computers and Operations Research v 29 n 8 July. p 1041-1058
CODEN: CMORAP  ISSN: 0305-0548
Language: English
Abstract: This paper presents a new mathematical programming formulation for the problem of determining the optimal manner in which several product rolls of given sizes are to be cut out of raw rolls of one or more standard types.The objective is to be perform this task so as to maximize the profit talking account of the revenue from the sales, the costs of the original rolls, the costs of changing the cutting pattern and the costs of disposal of the trim. A mixed integer linear programming (MILP) model is proposed which is solved to global optimality using standard techniques.A number of example problems, including an industrial case study, are presented to illustrate the efficiency and applicability of the proposed model. One-dimensional cutting stock (trim loss) problems arise when production items must be physically divided into pieces with a diversity of sizes in one dimension (e.g. when slitting master rolls of paper into narrower width rolls). Such problems occur when there are no economies of scale associated with the production of the larger raw (master) rolls.In general, the objectives in solving such problems are to [5] : circle closed minimize trim loss; circle closed avoid production over-runs and/or; circle closed avoid unnecessary slitter setups.The above problems is particularly important in the paper converting industry when a set of paper rolls need to be cut from raw paper rolls.Since the width of a product is fully independent of the width of the raw paper a highly combinatorial proble arises.In general, the cutting process always produces inevitable trim-loss which has to be burned or processed in some waste treatment plant. Trim-loss problems in the paper industry have, in recent years, mainly been solved using heuristic rules.The practical problem formulation has, therefore, in most cases been restricted by the fact that the solution methods ought to be able to handle the entire problem.Consequently, only a suboptimal solution to the original problem has been obtained and very often this rather significant economic problenm has been left to a manual stage.This work presents a novel algorithm for efficiently determining optimal cutting patterns in the paper converting process. A mixed-integer linear programming model is proposed which is solved to global optimally using available computer tools.A number of example problems including an industrial case study are presented to illustrate the applicability of the proposed algorithm. copy 2002 Elsevier Science Ltd.All rights reserved.15 Refs.
Descriptors: *Linear programming;Operations research;Paper and pulp industry;Combinatorial mathematics;Algorithms
Identifiers: Mixed integer linear programming (MILP)
811.0.3 (Economics, Research [$ Miscellaneous)]811.1.2 (Papermaking Equipment)
921.5 (Optimization Techniques);912.3 (Operations Research);811.1 (Pulp [$ Paper)]921.4 (Combinatorial Mathematics, Includes Graph Theory, Set Theory);811.0 (General Topics in Paper Science & Technology)
921 (Applied Mathematics);912 (Industrial Engineering [$ Management)]811 (Cellulose, Paper & Wood Products)
End of record 2
DIALOG No: 05761208  EI Monthly No: EIP01015478008
Title: Computer cutting pattern generation of membrane structures
Author: Xia, Xiaoyan;Meek, John L.
Corporate Source: Univ of Queensland, Brisbane, Australia
Source: International Journal of Space Structures v 15 n 2 2000. p 95-110
Publication Year: 2000
CODEN: ISSTER  ISSN: 0266-3511
Language: English
Document Type: JA;(Journal Article)  Treatment Code: A;(Applications);T;(Theoretical)
Abstract: This paper sets out a simple design procedure for generating the cutting patterns of a membrane surface which can then be used for a variety of purposes, including fabric of tension surface. It does this by pre-defining the requirements of the cutting pattern which is set out by the designer on an initially flat surface. A cable net is used for the approximating surface and the cables approximate the warp and weft directions of the fabric (see our previous paper on shape generation).The present work designs the procedure and gives examples of results of the shape finding of a surface with a number of different cutting patterns. An example of a compression membrane surface is also given.(Author abstract) 21 Refs.
Descriptors: *Fabrics;Computer aided design;Cutting; Computer simulation;Computational geometry;Computer graphics;Numerical methods
Identifiers: Computer cutting pattern generation; Membrane structures;Cable net
819.4 (Fiber Products);723.5 (Computer Applications);921.6 (Numerical Methods)
819 (Textile [$ Fiber Technology)]723 (Computer Software);921 (Applied Mathematics)
End of record 6
DIALOG No: 04854881  EI Monthly No: EIP97103898612
Title: Textile structures: A comparison of several cutting pattern methods
Author: Galasko, G.;Leon, J.C.;Trompette, R.;Veron, P.
Corporate Source: Technical Univ of Budapest, Budapest, Hung
Source: International Journal of Space Structures v 12 n 1 1997. p 9-18
Publication Year: 1997
Language: English
Abstract: The performances of three cutting pattern methods are compared by means of two specific and quite different examples: a hyperbolic paraboloid and a pan of a sixteenth of a sphere. It is shown that the results obtained are significantly different, something which can explain the difficulties sometimes encountered during the practical erection of tensile structures despite a convenient shape definition.(Author abstract) 11 Refs.
Descriptors: *Structural analysis;Textiles;Tensile strength
Identifiers: Cutting pattern methods; Textile structures
408.1 (Structural Design, General)
408 (Structural Design);819 (Textile & Fiber Technology)
End of record 1
DIALOG No: 05689737  EI Monthly No: EIP00105367449
Title: Static and dynamic analysis of partially wrinkled membrane structures
Author: Adler, Aaron L.;Mikulas, Martin M.;Hedgepeth, John M.
Corporate Source: Univ of Colorado, Boulder, CO, USA
Conference Title: 41st AIAA/ASME/ASCE/AHS/ASC Structures, Structural Dynamics, and Materials Conference and ExhibitAIAA/ASME/AHS Adaptive Structures ForumAIAA Non-Deterministic Approaches ForumAIAA Space Inflatables Forum
Conference Location: Atlanta, GA, USA  Conference Date: 19000403-19000406
Source: Collection of Technical Papers - AIAA/ASME/ASCE/AHS/ASC Structures, Structural Dynamics and Materials Conference v 4 2000. AIAA, Reston, VA, USA. p 158-171 AIAA-2000-1810
CODEN: CPSCDO  ISSN: 0273-4508
Language: English
Conference Number: 57446
Document Type: CA;(Conference Article)  Treatment Code: T;(Theoretical);X;(Experimental)
Abstract: With the number of space vehicle designs considering tensioned membrane structures (like the NGST sunshield and some Space Based Radar systems) increasing, understanding of their behavior is becoming necessary. Solving tensioned membrane problems using current standard commercial finite element codes, such as NASTRAN, is difficult or impossible when structural wrinkles form. This proposal discusses the development of modeling techniques for static and dynamic analysis of partially wrinkled membrane structures. The research uses two finite element approaches to model and simulate the effects of structural wrinkles in a membrane structure. Both experimental and finite element studies are currently under way with several example problems being studied.(Author abstract)
Descriptors: *Structural analysis;Problem solving;Finite element method;Computer simulation;Deformation;Mathematical models
Identifiers: Wrinkled membrane structures
408.1 (Structural Design, General);921.6 (Numerical Methods);723.5 (Computer Applications)
408 (Structural Design);921 (Applied Mathematics);723 (Computer Software)
End of record 6
DIALOG No: 05512262  EI Monthly No: EIP00035102339
Title: Shape-stress trade-off design of membrane structures for specified sequence of boundary shapes
Author: Ohsaki, M.;Uetani, K.
Corporate Source: Kyoto Univ, Kyoto, Jpn
Source: Computer Methods in Applied Mechanics and Engineering v 182 n 1-2 Feb 4 2000. p 73-88
CODEN: CMMECC  ISSN: 0045-7825
Language: English
Abstract: A new method is presented for parametrically generating optimal shapes and stresses of a membrane structure supported by a frame. The problem considered here is a so called trade-off design problem where the weighted sum of the deviations of the initial stress and the shape from the desired distribution is to be minimized.The membrane is discretized by using the finite element method, and optimal shapes are expanded with respect to a parameter defining the shape of the boundary frame. An approximate method is presented without exact calculation of the Hessian of the stresses with respect to the nodal coordinates.The explicit developability conditions derived by the authors are used to guarantee the curved surface to be reduced to a set of plane cutting patterns after removing the pretensioning force.In the examples, trade-off designs are found for an HP-type membrane structure and the efficiency of the proposed method is discussed. (Author abstract) 24 Refs.
Descriptors: *Finite element method;Approximation theory;Stress analysis;Deformation;Nonlinear equations;Strain;Stress relaxation;Mathematical programming;Optimization;Boundary conditions
Identifiers: Pretensioning;Homotopy method
921.6 (Numerical Methods);931.1 (Mechanics);921.2 (Calculus);921.5 (Optimization Techniques)
921 (Applied Mathematics);931 (Applied Physics)
End of record 30
还有
[58] H.J.Scheck.The force density method for form finding and computation of general networks.Computer Method in Applied Mechanics and Engineering. Vol.3, pp.115-134
[59] M.R.Barnes.Formfinding and analysis of prestressed net and membranes.Computer & Structures, Vol.30, No.3, 1988
[60] M.R. Barnes. Formfinding and analysis of tension structures by dynamic relaxation. Int. J. of Space Structure. Vol. 14(2), 1999
[61] Bletzinger etal. General finite element approach to the form finding of tensile structures by the updated reference strategy. Int. J. of Space Structure. Vol. 14(2), 1999
[62] Ishii Kazuo Form finding analysis in consideration of cutting patterns of membrane structures. Int. J. of Space Structure. Vol. 14(2), 1999
[63] Meek, John L. etal. Computer shape finding of form structures. Int. J. of Space Structure. Vol. 14(2), 1999
[64]Lewis. W. J., Lewis. T. S. Application of Formian and dynamic relaxation to the form finding of miminal surfaces. J of IASS, Vol.37(122), 1996
[65] Gosling, P.D, Lewis, W. S. Optional structural membrane-2: Form-finding of prestressed membrane using a curved quadrilateral finite element for surface definition. Computer & Structure. Vol. 61(5), 1996
[66] C.J.K. Williams. The use of modified Bezier Triangles for the form finding and analysis of cable net structures. Structural Engineering Review, Vol.6(3-4), 1994
[67] L.Grundig.Minimal surface finding forms of structural membranes. Computer & Structures, Vol.30, No.3, 1988
[68] K. Linkwitz etal. Optimizing the shape of the roof of the Olympic Stadium, Montreal. Structural Engineering Review, 1998,1, 225-232
[69] K. Linkwitz. About formfinding of double-curved structures. Engineering Structures. Vol.21, 1999
[70] Wu.B., Du.X., Tan.H. Three-dimensional nonlinear analysis of membranes. Computer & Structures, 1996, Vol.59, No.4, pp.601-605
[71]B. Foster. Cable and membrane roofs ― a historical survey. Structural Eng. Review. Vol. 6(3-4), 1994
[72] R. B. Haber etal. An integrated design system for cable reinforced membranes using interactive computer graphics. Computer & Structures. Vol. 14(3-4), 1981
[73] B.T. Davis. Primary supports:Masts, arches,anchorages.
[74] Barnes, Wakefield. Formfinding, analysis and patterning of surface-stressed structures.
[75] E. Haug. Numerical design of membranes.
[76] Vinzenz Sedlak. Aspects of detailing and component selection in memebrane structures.
[77] John.F. Howell. Physical modeling for loading and performance evaluation of membrane structures.
[78] Peter Kneen. Shape determination and analysis
雾里看花
积分 167
帖子 105
2002-12-27 10:16    顶部
收集不全望谅
膜结构的裁剪分析
【主文件记录号】274980
【学位论文题名】膜结构的裁剪分析
【 论文作者 】聂世华
【 作者专业 】结构工程
【 授予学位 】硕
【 导师姓名 】钱若军
【授予学位单位】同济大学
【原文馆藏号码】Y0328966
【中图法分类号】TU33
【 论文总页数 】68页
【论文出版时间】2000.3
【 关 键 词 】非线性有限单元法; 等效节点力法; 动态规划法; 裁剪分析; 膜结构
【 文  摘 】该论文主要讨论了膜结构的裁剪分析方法,并提出了一种裁剪分析方法,即等效节点力裁剪分析方法,同时
               以有限元理论和奇异值分解原理为基础推导出相应的计算公式。等效节点力方法是通过反复修正预先假定的
               平面试形状使其逐步逼近待展开的空间曲面而进行曲面展开的。该方法以矩阵的奇异值分值、有限元理论为
               基础,并且假定膜单元可以双向受力。如果把预应力对结构刚度的影响转化为结等效结点荷载的修正,等效
               节点力裁剪分析方法也可以把张力膜结构由预应力状态还原到无应力状态,而且可以避免求解病态方程组。
               该文也提出了一种几何剪分析方法。最后给出了两个不同裁剪分析的例子:一个双曲抛物面和一个削顶的十
               六分之一球面。这些例子表明上述方法是正确、实用和有效的。
万方数据股份有限公司
电话:(010)88018118 传真:(010)88018128 Email:wanfang@wanfangdata.com.cn
膜结构的裁剪分析
【主文件记录号】273306
【学位论文题名】膜结构的裁剪分析
【 论文作者 】陈英时
【 作者专业 】结构工程
【 授予学位 】硕
【 导师姓名 】沈祖炎
【授予学位单位】同济大学
【原文馆藏号码】Y0327292
【中图法分类号】TU31
【 论文总页数 】59页
【论文出版时间】2000.3
【 关 键 词 】应力释放; 极值法; 有限元法; 测地线法; 三角剖分法; 测地线; 最优化方法; 裁剪; 膜结构
【 文  摘 】该文列举了国内外裁剪分析的主要算法,并通过算例对它们进行了比较和分析,指出了它们的特点及适用场
               合。膜面的划分曲线必须满足膜材幅宽的要求,一般采用测地线作为划分曲线。该文给出了求解测地线的算
               法,它们分别适用于由公式定义及离散为网格的曲面。这些算法的主要问题在于约束方程的选取,网格与曲
               面的差别也将导致误差。该文给出了细分网格的算法。该文给出了基于几何及平衡模型的展开算法,它们的
               主要目标是减少展开误差。通过对比分析指出:几何方法简单、快速,精度低。有限无法及极值方法灵活。
               精度高,但存在不收敛于错误结果的可能。该文指出试形状对于这些方法的重要意义。该文介绍了用实验方
               法确定应力释放的过程。用有限元方法定性地分析了应力释放。
万方数据股份有限公司
膜结构技术及其形态分析的力密度方法
【主文件记录号】266904
【学位论文题名】膜结构技术及其形态分析的力密度方法
【 论文作者 】马政纲
【 作者专业 】结构工程学
【 授予学位 】硕
【 导师姓名 】罗尧治
【授予学位单位】浙江大学
【原文馆藏号码】Y320389
【中图法分类号】TU331
【 论文总页数 】81页
【论文出版时间】2000.1
【 关 键 词 】极小曲面; 静力性能分析; 形态分析; 力密度; 膜结构
【 文  摘 】该文的工作主要分为两部分,一部分是采用力密度法进行对膜结构的形态分析,第二部分是对膜结构的静力
               性能作了研究。形态分析是膜结构分析的第一步。力密度法是将一结构理解为具有各自的物理特性或力学特
               性的枝或杆的网络集合,并用枝点矩阵,坐标矩阵,各枝的物理特性如杆内力用矩阵来完整的描述一个网络
               。通过选择和调整力密度值,得到关于节点坐标的线性方程组。同时在力密度法线性基础上从实际工程出发
               对其作了进一步的扩充,建立了附加约束条件下(结构内单元等长、等应力、位置控制等条件)的非线性力密
               度法,以及提出了膜结构形态分析的极小曲面法。另外解决了对混合大跨结构进行形态分析的方法--和谐模
               态法,对以后研究和设计大跨结构提供了一定的依据。该文第二部分是膜结构的静力性能分析,采用修正的
               拉格朗日法(U.L法)导出三角形膜单元的刚度矩阵,建立膜结构 的非线性有限元基本方程,通过平衡迭代求
               解非线性方程,验证了膜结构的非线性特性。
膜结构的下料研究及程序设计
【主文件记录号】259204
【学位论文题名】膜结构的下料研究及程序设计
【 论文作者 】杨维国
【 作者专业 】结构工程
【 授予学位 】硕
【 导师姓名 】徐国彬; 高日
【授予学位单位】北方交通大学
【原文馆藏号码】Y313686
【中图法分类号】TU441
【 论文总页数 】63页
【论文出版时间】1999.1
【 关 键 词 】初应力; 板单元; 三角形网络; 拓扑学; 裁剪分析; 膜结构
【 文  摘 】膜结构是一种柔性结构,它的结构分析了与传统的刚性结构有显著不同。它特有的找形分析,裁减下料分析
               及风振反应分析成为摆在文大结构师面前的一道难题。该文作为膜结构设计研究的一部分,主要针对膜结构
               的下料裁剪作一些研究。作者首先应用拓扑学及几何学原理建立了膜结构的裁剪下料分析理论,提出了指导
               膜结构裁剪的一般公式。并以此为基础总结出将空间各种形式的曲面剖分成平面的一般方法。为验证理论的
               正确性及方法的可行性,作者编制了将一球面用三角形网格剖分的计算程序,程序中由用户输入控制近似程
               序的参数,程序的计算结果为FORTRAN77数据文件。作者应用自编的文本文件与AutoCAD之间的接口程序,实
               现了剖分结果的自动成图显示,使用户可以在图形界面中多视角,多方位,直观的观察剖分结果,并根据自
               己的审美观选择合理的剖分形式。针对剖分后的每一膜平面,作者运用SAP软件(采用板单元,输入膜的材料
               参数),反向施加膜成形时在空间的内部应力边界条件,求出变形后的膜形状,这样便得到了膜的下料图。最
               后,作者应用上所述及的理论及自己所编的程序,将一半径为10米的半形膜结构按用户不同的剖分精度要求
               进行了剖分。并将剖分结果施加力的边界条件,得到了有真正参考价值的膜的下料图。
普通张拉膜与张拉整体膜结构形状及静力性能分析
【主文件记录号】259203
【学位论文题名】普通张拉膜与张拉整体膜结构形状及静力性能分析
【 论文作者 】姜义高
【 作者专业 】结构工程
【 授予学位 】硕
【 导师姓名 】徐国彬; 高日
【授予学位单位】北方交通大学
【原文馆藏号码】Y313685
【中图法分类号】U441
【 论文总页数 】74页
【论文出版时间】1999.2
【 关 键 词 】静力分析; 预应力; 张拉整体; 几何非线性; 膜结构
【 文  摘 】该文回顾了模结构的发展历史,对国内外膜结构的研究现状进行了综述。通过增量形式的虚功方程,采用修
               正的拉格朗日坐标描述法,建立了各种形函数的几何非线性方程,推导了三角形膜单元和二节点索单元的单
               元刚度矩阵。简单张拉膜结构中较为普遍的一种形式。该文对简单张拉膜结构的曲面构成进行了较为详细的
               分析,得出了张拉膜曲面是由曲面等结论。该文编制了简单膜结构初始形状的程序,并通过实例验证了程序
               的正确性;此外,该文还研究了鞍形张拉膜结构在风、雪等荷载作用下的性能等。张拉整体膜结构是膜结构
               中较为理想的一种状态,但这种结构的张拉整体状态、自平衡、自适应、非保守体系等特点,使其在结构分
               析上较其他空间结构复杂。该文较为详细的研究了这种结构在各种荷载作用下的反应,找出了这种结构较为
               一般的受力规律;分析了不同预应力对张拉整体膜结构的刚度及受力性能的影响,得出了一些有益的结论。
索膜结构静力分析及膜材料力学特性研究
【主文件记录号】259200
【学位论文题名】索膜结构静力分析及膜材料力学特性研究
【 论文作者 】李沐钢
【 作者专业 】结构工程
【 授予学位 】硕
【 导师姓名 】徐国彬; 高日
【授予学位单位】北方交通大学
【原文馆藏号码】Y313682
【中图法分类号】U441
【 论文总页数 】59页
【论文出版时间】1999.1
【 关 键 词 】力学特性; 膜材料; 静力分析; 膜结构; 索
【 文  摘 】首先该文论述了膜结构的概念和发展状况,推导了薄膜结构有限元分析表达式。该文的创新性工作主要表现
               在以下:膜结构之所以有以上提到的许多优点,归功于新膜材料,所以该文对国内目前尚不够清楚明确指标
               的某些国产膜材料进行力学性能试验,得到以下几个主要特性:断裂强度、伸长率、本构关系、抗撕裂强度
               、徐变性能。文中还收集了进口膜材的主要差距是耐久性差、徐变性能显著、强度低。对于设计者而言,进
               口膜村使用预应力技术不用二次张拉和超张拉且强度高,是理想的选择材料。该文另外一个重要工作是借助
               于ANSYS程序进行膜结构的静力分析。由于ANSYS程序中的membrane与实际的膜结构有差别,如程序中的
               membrane可心承受压力,不能加预应力,所以该文根据实际施工情况提出一种支座位移法。用该法可解决膜
               结构的找形问题,从而为以后的裁剪下料、风荷载分析奠定了基础。该文还分析了膜结构的变形、应力分布
               (从而决定是否曲面光滑)与荷载、刚度等关系,得出一此圾益的结论。最后,该文对膜结构的未来进行了展
               望。
张拉整体膜结构的风振响应时域分析
【主文件记录号】259199
【学位论文题名】张拉整体膜结构的风振响应时域分析
【 论文作者 】欧阳潞
【 作者专业 】结构工程
【 授予学位 】硕
【 导师姓名 】徐国彬; 高日
【授予学位单位】北方交通大学
【原文馆藏号码】Y313681
【中图法分类号】U441
【 论文总页数 】75页
【论文出版时间】1999.1
【 关 键 词 】几何非线性; 时域分析; 风振响应; 张拉整体膜结构
【 文  摘 】张拉整体(Tensegrity)膜结构是四十多年来逐步发展起来的一种新型空间结构体系,它符合了空间结构向着
               跨度更大、结构形式更美观的方向发展的趋势。该文主要从张拉整体膜结构体系在风荷载作用下的动力是域
               分析方面进行探讨与研究。在时域内进行风振响应分析方面进行探讨与研究。在时域内进行风振响应分析首
               先要解决的问题就是根据风速功率谱来产生结构上的不同点的一系列风速曲线。该文根据脉动风特性,采用
               Davenport谱或Panofsky谱,引入适当的三维空间相关性公式,并针对大跨度张足,给出了具有空间相关性风
               场的计算机仿真方法,编制了相应计算机程序ARWGEN,并首次在计算机仿真程序中考虑随机过程ε<'i>(t)和
               S<'ii><,ε>(n)。该编制了风速时程曲线数据文件与ANSYS软件的接口程序。自动生成符合张拉整体膜结构风
               振响应分析要求的荷载步议论挫而为ANSYS软件计算时所直接采用,减轻了荷载输入时的繁重工作。然后用
               ANSYS软件计算张拉整体膜设计提供一定的参考资料。该文采用密集索网集索网来摸拟膜块。作者证明这种模
               拟方式是有效的、足够精确的。
网壳膜结构的非线性静力、动力和地震响应分析
【主文件记录号】259131
【学位论文题名】网壳膜结构的非线性静力、动力和地震响应分析
【 论文作者 】鲍三
【 作者专业 】结构工程
【 授予学位 】硕
【 导师姓名 】徐国彬; 高日
【授予学位单位】北方交通大学
【原文馆藏号码】Y313613
【中图法分类号】TU311
【 论文总页数 】85页
【论文出版时间】1999.3
【 关 键 词 】地震响应; 动力特性; 静力特性; 几何非线性; 膜单元; 空间杆单元; 空间梁单元; 网壳膜结构
【 文  摘 】该文在回顾了膜结构的发展的历史,对国内膜结构的研究现状进行了综述后,根据连续体非线必有限元理论
               ,推导了在T.L(Total Lagrangian)描述和U.L(Updated Lagrangian)描述下的空间梁单元、空间杆单元及膜
               单元的几何非线性刚度矩阵、单元等效节点力向量和有限元增量平衡方程及座标转换矩阵。推导了空间梁单
               元、空间杆单元及膜单元的一致质量矩阵与集中质量矩阵及结构的阻尼矩阵;给出动力特性分析所用子窨迭
               代法及弹性地震响应分析所用的振型分解反应谱法。对地震波的选择作了讨论,推导并给 出在三向或单向地
               震输入下网壳膜结构的几何非线性地震响应计算列式和计算策略。分别对两种网壳膜结构模型(1.空间梁单元
               与膜单元模型;2.空间杆单元与膜单元模型)进行非线性静力特性分析。采用时程分析法分析了K6型网壳膜结
               构的几何非线性水平地震响应及竖向地震响应,得出结构的位移及内力分布规律,并与振分解反应谱法的内
               力计算结果进行了比较。
薄膜结构的初始形态设计、风振响应分析及风洞实验研究
【主文件记录号】247324
【学位论文题名】薄膜结构的初始形态设计、风振响应分析及风洞实验研究
【 论文作者 】向阳
【 作者专业 】结构工程
【 授予学位 】博
【 导师姓名 】沈世钊
【授予学位单位】哈尔滨建筑大学
【原文馆藏号码】Y301303
【中图法分类号】TU359
【 论文总页数 】130页
【论文出版时间】1998.11
【 关 键 词 】裁剪; 风洞; 风振响应; 随机模拟; 初始形态; 薄膜结构
【 文  摘 】该文发展建立了薄膜结构初始形态设计的理论方法。进行了薄膜结构的较系统的静力性能参数分析。进行了
               伞形结构的刚性模型的风洞实验。发展建立了薄膜结构的随机模拟风振响应分析方法。建立了一种应用广义
               泛函变分取极值得到膜结构曲面上的测地线,并根则地线计算裁剪线而生成裁剪图的方法。该文编制了较完
               整的薄膜结构设计软件及相关的计算分析程序。
薄膜结构的风振响应分析及抗风设计研究
【主文件记录号】244420
【学位论文题名】薄膜结构的风振响应分析及抗风设计研究
【 论文作者 】陈新礼
【 作者专业 】结构工程
【 授予学位 】硕
【 导师姓名 】沈世钊
【授予学位单位】哈尔滨建筑大学
【原文馆藏号码】Y298399
【中图法分类号】TU351.3; TY351.5
【 论文总页数 】74页
【论文出版时间】1999.6
【 关 键 词 】抗风设计; 风振响应; 动力性能; 薄膜结构
【 文  摘 】鞍形和伞形膜结构是两种典型的张拉式膜结构。该文对它们进行了大量的计算,分析了它们的风激动力性能
               ,并对风振响应进行了比较系统的参数分析;该文还对薄膜结构的抗风设计进行了初步研究,对薄膜结构的
               风振系数进行了参数分析。得到的一些结论可供工程实际参考。
张力膜结构形状优化
【主文件记录号】238347
【学位论文题名】张力膜结构形状优化
【 论文作者 】冯星
【 作者专业 】结构工程
【 授予学位 】硕
【 导师姓名 】蓝天
【授予学位单位】中国建筑科学研究院
【原文馆藏号码】Y292326
【中图法分类号】TU359
【 论文总页数 】72页
【论文出版时间】1999.2
【 关 键 词 】敏感度分析; 形状优化; 线性孔斯曲面法; 张力膜结构
【 文  摘 】该文对张力膜结构形状优化进行了系统的研究,主要解决了以下几方面的问题:1.确定了张力膜结构形状
               优化问题所包含的内容,分别为优化模型建立、几何模型建立、结构分析、数学优化方法。介绍了求解优化
               问题的基本步骤;2.在张力膜结构有限元分析的基础上建立了形状优化模型。模型以膜加索总造价为目标
               函数,取结构曲面控制点、膜和索预张力及索截面积为优化变量,约束函数考虑受荷后的应力和位移约束;
               3.以线性孔斯曲面法描述结构几何曲面,以几何非线性有限元法进行结构分析,数学优化方法采用无需梯
               度信息的复形法来处理非线性规划问题;4.完整的作了一20m跨的张力膜结构形状优化实例分析。根据
               该文提出的优化模型及求解步骤,由编制的程序进行优化计算。计算结果表明该张力膜结构矢跨比、垂跨比
               的优化区间为0.07 ̄0.10;5.对张力膜结构形状优化的敏感度分析作了理论探讨。介绍了分析的
               难度和分析的步骤方法,详细的推导了有关公式。
用曲面膜单元建立的膜结构静力动力分析理论,计算机辅助设计系统及模型实验研究
【主文件记录号】228005
【学位论文题名】用曲面膜单元建立的膜结构静力动力分析理论,计算机辅助设计系统及模型实验研究
【 论文作者 】叶小兵
【 作者专业 】结构工程
【 授予学位 】博
【 导师姓名 】吴健生
【授予学位单位】天津大学
【原文馆藏号码】Y281981
【中图法分类号】TU311; TP391.7
【 论文总页数 】110页
【论文出版时间】1998.2
【 关 键 词 】结构设计; CAD; 结构分析; 有限元法; 几何非线性; 曲面膜单元; 膜结构
【 文  摘 】膜结构是一种全新的建筑结构形式,1997年上海8万人体育场的建成,对膜结构这种美观先地的结构形
               式在中国的发展和普及起到很大的推动作用。值此中国膜结构发展的关键时候,该文在总结该课题组过去研
               究成果的基础上,参考国外的技术资料,独立提出了新的更精确的计算理论,编制了一整套膜结构交互式计
               算机辅助设计系统;设计制作了最复杂的膜结构建筑的模型,通过大量的计算实践,总结出很多膜结构的设
               计规律,为把这项科研成果推向实际工程奠定了坚实的基础。
张拉膜结构全过程分析及实验验证
【主文件记录号】227899
【学位论文题名】张拉膜结构全过程分析及实验验证
【 论文作者 】李中立
【 作者专业 】结构工程
【 授予学位 】博
【 导师姓名 】吴健生
【授予学位单位】天津大学
【原文馆藏号码】Y281875
【中图法分类号】TU33
【 论文总页数 】107页
【论文出版时间】1997.7
【 关 键 词 】荷载分析; 找形分析; 平面热力 学问题; 动态规划原理; 几何非线性有限单元法; 动力松弛法; 力密度法
               ; 膜结构
【 文  摘 】该文系统地回顾了国外膜结构发展的过程和理论方法,指出了其形式由充气到张拉向索穹顶和张拉整体体系
               发展的历史阶段性,并分析了中国膜结构的应用现状、前景和存在的问题。剖析了力密度法分析膜结构的内
               核,分析了该方法的特点,给出了索网力转换膜单元力的具体技术细节,该方法用于找形分析非常快捷。剖
               析了动力松弛法用于膜结构的实质,解决了该方法用于膜结构找形分析和荷载分析时遇到的技术细节。用固
               体力学大变形大位移几何非线性有限单元法原理,推导了三角形膜单元和索单元的刚度矩阵,针对膜结构分
               析的具体特点,给出了膜材经纬向对膜单元本构关系的影响公式以及索膜单元松弛时的处理。提出把动态规
               划原理和平面热力学问题相结合用于膜结构的剪裁分析上,该方法多变灵活、精度高,从而解决了膜结构制
               作过程中的关键性技术问题,为膜结构的工程实践打下了良好的基础。
张力膜结构的理论模型及其非线性有限元分析研究
【主文件记录号】163164
【学位论文题名】张力膜结构的理论模型及其非线性有限元分析研究
【 论文作者 】胥传喜
【 作者专业 】结构工程
【 授予学位 】硕
【 导师姓名 】钱若军; 刘瑞
【授予学位单位】河海大学
【原文馆藏号码】Y217125
【中图法分类号】TU33
【 论文总页数 】60页
【论文出版时间】1995.9
【 关 键 词 】非线性有限元分析; 理论模型; 张力膜结构
【 文  摘 】根据能量原理,推导了分析任意形状张力膜结构的非线性有限元方法,及其相应的三角形膜元的刚度矩阵、
               赘余力矩阵、应力矩阵和等效结点力矩阵,建立了张力膜结构非线性分析的理论模型。张力膜结构的全过程
               分析包括形状判定、静动力分析及裁剪分析等几方面,该文第三部分就此进行了初步探讨,并重点就几何非
               线性分析问题进行了研究,编制了相应的程序,进行了算例分析。
薄膜结构非线性分析和材料双轴拉伸试验
【主文件记录号】149277
【学位论文题名】薄膜结构非线性分析和材料双轴拉伸试验
【 论文作者 】刘文彬
【 作者专业 】结构工程
【 授予学位 】博
【 导师姓名 】吴健生
【授予学位单位】天津大学
【原文馆藏号码】Y153238
【中图法分类号】O342
【 论文总页数 】72页
【论文出版时间】1993.8
张力膜结构形体的计算机实现与分析
【主文件记录号】142028
【学位论文题名】张力膜结构形体的计算机实现与分析
【 论文作者 】高振锋
【 授予学位 】硕
【 导师姓名 】沈祖炎
【授予学位单位】同济大学
【原文馆藏号码】Y145986
【中图法分类号】TU311.4
【 论文总页数 】97页
【 文摘语种 】英文文摘
【论文出版时间】1993.3
膜结构CAD和非线性有限元分析
【主文件记录号】090956
【学位论文题名】膜结构CAD和非线性有限元分析
【 论文作者 】沈金
【 作者专业 】结构工程
【 授予学位 】硕
【 导师姓名 】吴健生
【授予学位单位】天津大学
【原文馆藏号码】Y094876
【中图法分类号】TU311
【 论文总页数 】93页
【 文摘语种 】英文文摘
【论文出版时间】1991.1
索网结构和薄膜结构的形状确定分析
【主文件记录号】115380
【学位论文题名】索网结构和薄膜结构的形状确定分析
【 论文作者 】宋昌永
【 作者专业 】结构工程
【 授予学位 】硕
【 导师姓名 】沈世钊
【授予学位单位】哈尔滨建筑工程学院
【原文馆藏号码】Y119330
【中图法分类号】TU351.1
【 论文总页数 】96页
【 文摘语种 】英文文摘
【论文出版时间】1992.3
薄膜结构非线性分析、材料拉伸特性实验及风荷载研究
【主文件记录号】035253
【学位论文题名】薄膜结构非线性分析、材料拉伸特性实验及风荷载研究
【 论文作者 】邵晓方
【 作者专业 】结构工程
【 授予学位 】博
【 导师姓名 】吴健生
【授予学位单位】天津大学
【原文馆藏号码】Y172854
【中图法分类号】TU312; TU33
【 论文总页数 】97页
【论文出版时间】1993.3
superowen
积分 301
帖子 156
2003-9-21 21:36    顶部
我想找 H.J.Scheck.The force density method for form finding and computation of general networks.Computer Method in Applied Mechanics and Engineering. Vol.3, pp.115-134
不知道谁手上有?
lgn
积分 36
帖子 23
2003-10-24 04:20    顶部
我有今年夏天在西班牙的膜结构会议的全部论文和部分电子论文
现在我先提供一篇德国K.-U. Bletzinger的论文
EQUILIBRIUM CONSISTENT ANISOTROPIC STRESS FIELDS IN
MEMBRANE DESIGN
需要的人请来email索取,勿在此跟帖提供email,明天或后天我会集中发给需要的人。大小有713K,PDF; 我只发一次
lgn
积分 36
帖子 23
2003-10-24 04:32    顶部
膜结构找形有三种方法,德国的力密度法,英国的动力松弛法和有限元法
英国的动力松弛法的几个主要人物
Barnes, M.      University of Bath
Wakefiled, D.   www.tensys.com
Lewis, W. J      University of warwick
Barnes, wakefield and Papadrakakis, M(后者在希腊,一个重量级的人物,在结构优化领域) 都是  City University (London)  70年代末和80年代初的博士
lgn
积分 36
帖子 23
2003-10-24 20:12    顶部
今天再提供一篇论文, 一个著名的德国人,讲述了
Recent Development in the analytical design of textile membranes
需要者请来email索取,勿在此跟帖提供email,我明天会发给有兴趣的人
