在帮助文件中就有
Keyboard Shortcuts
Shortcut keys for menu commands are indicated in the menus and/or related dialog boxes. Most menus, menu items, and dialog box controls are accessible by pressing the Alt key and the underlined letter (also called an shortcut key) associated with that control. STAAD.Pro also supports shortcut keys for window and dialog box navigation and other functions.
Working with files Action Shortcut
Create a new document using the New model wizard. <Ctrl+N>
Open an existing STAAD.Pro project file. <Ctrl+O>
Save the current project file. <Ctrl+S>
Print the output report. <Ctrl+P>
Quit the program. <Alt+F4>
or
<Alt+F+X>
Editing documents Action Shortcut
Undo an action. <Ctrl+Z>
Redo an action <Ctrl+Y>
Cancel an action. <Esc>
Copy a selected element. <Ctrl+C>
Paste an element from the clipboard. <Ctrl+V>
Cut an element (copies the selected element to the clipboard and deletes the selected copy). <Ctrl+X>
Delete a selected element. <Del>
Navigating the view window Action Shortcut
Rotate model about the global X axis. Up or Down arrow keys
Rotate model about the global Y axis. Left or Right arrow keys
Rotate model about the global Z axis. Ctrl+Up or down arrow keys
Close the current active view. <Ctrl+F4>
Open the Orientation dialog box, which is used to precisely control the zoom and rotation of the active view window. <F4>
Refresh the active view window. <F5>
Tile all view windows, tables, forms, etc. horizontally. <Shift+F4>
Cascade all view windows, tables, forms, etc. <Shift+F5>
Tile all view windows, tables, forms, etc. vertically. <Ctrl+Shift+F4>
Working with models Action Shortcut
Create a new group from selected entities. <Ctrl+G>
Initiate the analysis and, if used, batch design for the current input file. <Ctrl+F5>
Toggling the display of model labels Action Shortcut
Display member specifications (i.e., truss, beta angle, etc.). <Shift+A>
Show axes window. <Ctrl+Shift+A>
Display beam numbers. <Shift+B>
Display the design brief for physical members. <Ctrl+Shift+B>
Display solid element numbers. <Shift+C>
Display dimensions. <Shift+D>
Display the beam ends, color coded for start and end. <Shift+E>
Display the design envelope for physical members. <Ctrl+Shift+E>
Display floor loading. <Shift+F>
Show the diagram information. <Shift+G>
Display the design group for physical members. <Ctrl+Shift+G>
Display the wind load tributary area. <Shift+H>
Show axes at origin. <Shift+I>
Display the entity reference numbers. <Shift+J>
Display node point labels. <Shift+K>
Display the master-slave links. <Shift+L>
Display the material label for each entity. <Shift+M>
Display physical member numbers. <Ctrl+Shift+M>
Display node numbers. <Shift+N>
Display the local beam axis (beam orientation). <Shift+O>
Display plate element numbers. <Shift+P>
Display surface element numbers. <Ctrl+Shift+P>
Display member/element releases. <Shift+R>
Display the support node labels. <Shift+S>
Display the local plate element axis (plate orientation). <Shift+T>
Display the local surface element axis (surface orientation). <Ctrl+Shift+T>
Display load values. <Shift+V>
Display wind loads. <Shift+W>
Display member sections. <Shift+X>
Display the floor load distribution. <Shift+Y>
