staad beava ( 2004)不能用,求救!
banach
The latest model I am inputing gives an error message when I try to run the influence surface generator.
"The Influence surrface results are missing or ivalid."
When I run the influence surface generator it gets to the point where it is calculating joint displacements. It never finishes and then displays the message above.
