有关节点的专业词汇,请指教。
snow-123321
slip-type和 The cyclic characteristics 在一篇关于柱脚的英文期刊里出现。哪位能帮个忙呢?谢谢!
baobao_jd
2005-11-21 11:42
slip-type承压型
The cyclic characteristics动力特性
仅供参考!!
snow-123321
2005-11-21 15:05
谢谢指教,但是关于柱脚有承压型的说法吗?non-slip-type 就是非承压型吗?
有点困惑
baobao_jd
2005-11-21 16:59
呵呵,我也是半桶水,在有些资料上看过,好象是指螺栓连接(承压型和摩擦型)中的承压型,具体可能要根据语言环境。我只是提供参考,因为我也是根据当时的语境理解的,不知道是不是正确的。
qingjun20001
2005-11-22 18:29
应该不是承压型,使美国的一种做法,国内没有。今天太晚了,稍后我找找资料贴出来。
snow-123321
2005-11-22 19:17
太好了。先谢过了!
我觉得好像是 滑移和动力特性。但是柱脚滑移是怎么回事?
ButlerBldg
2005-11-23 01:18
The cyclic characteristics of column base = the behavior of column base under cyclic loading.
Slip-type column base = under cyclic loading, due to the plastic elongation of anchor bolts, there will be a small gap between nuts and base pate,as a result, the friction between the nuts and base plate no longer exists, so, "slip" could occur between the nuts and base plate.That is why the author called them "slip-type" column base.
The authors of that paper invented a device which consists of a wedge and a spring.This wedge will fill up in the "small gap" between the nuts and the base plate, so, the friction will always be there and the column base will always be "non-slip".
With "non-slip" condition established, the authors then presented their findings about restoring forces in the anchor bolts.
Hope this will help.
snow-123321
2005-11-25 10:34
非常感谢,您的解释给了我莫大的帮助,在我准备论文的关键时刻。
谢谢您专门查看了这篇论文,您的解释更是让我豁然开朗。
真诚地感谢您!
