寻上海八万人体育馆的详细报道及图片
蓝凌
积分 196
帖子 117
2001-11-14 20:48    顶部
      请大家提供关于c,谢谢!
                                    《钢结构与建筑业》杂志社
wildly
积分 1158
帖子 344
2001-11-15 01:33    QQ 顶部
我这儿有一张照片不过是拿设计院朋友的。但只有一张不是很完整有需要的话可以上传。
蓝凌
积分 196
帖子 117
2001-11-15 12:59    顶部
谢谢,有劳了。
wildly
积分 1158
帖子 344
2001-11-17 22:18    QQ 顶部
不好意思上天搬家现在找不到了,我再找找看,找到了给你发过去.
North Steel
积分 507
帖子 284
2001-11-18 09:30    顶部
没准你指的是上海八万人体育(场),我在施工期间去看过,有几点了解:
1。规模较大,结构断面也不小。
2。屋面结构体系采用组合钢管悬挑空间桁架(最大挑出70几米),支承几公斤/M^2膜结构。其重量比极不合理。
3。风洞在CANADA 做的试验
4。屋面组合钢管悬挑空间桁架为平面体系,没有考虑利用屋面起伏和平面为椭圆形的受力有利条件,(这一点,我在工地问过设计负责人)。
5。如需了解体育场设计,建议去学习澳大利亚 PPHLIP COX (建筑师)的设计。
6。即使这样,也应该向设计人致敬,因为他们压力太大,回报太小。
谢谢
积分 9561
帖子 6093
2001-11-18 19:02    QQ 顶部
钢材是进口的,英钢。
节点是焊接空心球。
桁架梁式结构,受力单纯清晰,安装简单,可能是国内外不少著名体育场采用这种体系,而不是空间网架的原因。
微信号:nixnauy
hhux2002
积分 2128
帖子 1226
2001-12-15 13:07    顶部
The Shanghai Sports Centre features an 80,000-seat stadium for track-and-field events, soccer matches, and cultural and sports extravaganzas. The 61,700-square-meter building incorporates a 3-star 280-room hotel, an underground recreational athletics center, and parking for 1,600 cars. It is notable for being China's first long span fabric roof and the world's longest cantilevered steel truss roof. The project was a successful joint effort of Chinese and American engineers and contractors.
The structure consists of a continuous series of umbrellas held up by flying masts. The roof rises and dips as it makes its circuit around the field, following the elevation of the back of the stands. Large steel trusses match their extent as the roof cantilevers as much as 73 meters over them. The stands are covered with a 28,900-square-meter membrane of Teflon-coated Fiberglas, formed of trapezoidal panels inserted into the bays between the trusses. The complete cable-supported flying mast structure and the fabric covering were erected in less than three months, cutting the estimated schedule by 30 percent. The fabric is stretched between the 300-meter perimeter and the oval opening at the center. Each flying mast unit consists of four upper ridge cables, four bottom suspension cables and a flying vertical compression post. All cantilevered trusses are tilted slightly upward from their back supports, while flying posts are kept vertical and post heights are varied at each flying mast location.  Governed by the original arrangement of the cantilevered steel truss roof, the flying mast layout consists of 32 bays with 17 different types of fabric panel, with from one to three masts per bay depending on the cantilever lengths. Each bay formed by two adjacent trusses is trapezoidal.  Perimeter steel pipe framing has been introduced above the top chord of the trusses at each bay; it is connected with short posts to the top chord at the node joints. The raised pipe framing acts as a boundary-supporting structure for the roof. The panels, ridge cables and suspension cables are all anchored to it. The framing also provides a gutter for drainage in the radial direction of the roof and transfers roof loads to the supporting roof trusses.
Technical Data
Materials:
membrane        PTFE-coated glass-fiber fabric
Dimensions:
site area        190 000 m2
building area        100 000 m2
total floor area      170 000 m2
membrane covered area  28 900 m2
height        62.5 m
seats        80 000
Above info. from Weidlinger Associates
羊三皮 (羊三皮)
积分 3802
帖子 1540
2001-12-16 00:29    QQ 顶部
才搜寻的
上海八万人体育场于1997年10月建成,与上海体育馆(万体馆)、上海游泳馆、奥林匹克俱乐部(宾馆)、运动员之家连成一体,形成上海一流的体育城,是1997年第八届全国运动会的主会场。上海八万人体育场是一座造型呈马鞍形的建筑,占地19万平方米,拥有符合国际比赛标准的四季常绿的足球场和塑胶跑道等田径比赛设施;可容纳八万名观众的三层环型全天候看台和100套豪华型包厢;巨型彩色显示屏、摄影摄像监控自动测量显示系统和安全集卫、药检、新闻中心等设施。
   地址:天钥桥路666号
    上海八万人体育场位于上海西南部交通要脉一一地铁一号线和内环线交汇处,占地19万平方米,总建筑面积近17万平方米, 可容纳八万名观众,并设有近1600个停车泊位。
    体育场为直径300米、总标高70余米的巨型马鞍型建筑,中 央是一个105×68米、南北向的标准足球场,铺设从美国引进优良品种的四季常绿草坪;围绕球场的是意大利蒙多公司制造的9根塑胶跑道;场地上配备各种大型体育比赛所用的门类齐全的运动器材。在三层环形看台之间,设置了103套豪华包厢,包厢的正立面为落地玻璃,门外有20座专席。体育场上部是全国首推的可遮雨、避阳的受拉膜结构环形屋盖。体育场的灯光照明布置在东西两侧的环形屋盖上,在各种环境下都具有适宜、足够的亮度。体育场南面的看台上方矗立着两块面积各为108平方米的彩色电脑显示屏,用于显示体育竞赛比分和各种广告图文。主席台区域设置在体育场西首正中,安置了600个座椅。与之相应的地下层包括了贵宾厅和车库。贵宾厅总面积3000多平方米,乘专用电梯可直达主席台。
    另外,体育场还具有其它完备的设施,包括宾馆、娱乐场所、购物商场等。
    1997年10月12日,中华人民共和国第八届全国运动会在上海体育场揭幕。上海体育场以其宏伟的规模、一流的设施、齐全的功能而成为上海新三年标志性建筑之一。
    工程投资12.9亿元。
图片太小
湖南建设投资集团
ccc
积分 831
帖子 327
2001-12-23 18:14    顶部
版权声明:本文(包括照片)转载自far2000自由建筑报道网站
工程名称:上海八万人体育场
设计单位:上海现代设计集团
建造规模:170000平方米
建造信息:总建筑面积:17万m2
建筑地点:国家:中国 城市:上海
设计特点:
    体育场坐落于徐汇区,西面与原有的上海体育馆、游泳馆和奥林匹克俱乐部相连,整个基地组合形成上海体育中心。
    体育场建筑体形为直径273米的圆形平面,设有一片符合国际标准的草地足球场,环球场四周设400米跑道,整个比赛场地边缘设置一道宽3米的通行地沟,使赛场与观众席隔离。
    整个观众席的设计,根据观众最佳视觉质量图形分析,采用东西看台观众多,南北看台观众少的方式安排,形成不对称的平面及剖面。西看台为三层看台共83排,东看台为双层看台共63排,南北各为33排的双层看台。整个看台形成西面高东面低,南北二面更低的高低差落悬殊的马鞍形建筑外观,屋顶用半透明的白色"膜"(聚四氟乙烯)新型建筑材料,覆盖整个看台,可起遮阳、挡雨、抗风作用,充分显示大型体育场建筑的独特艺术形象。主席台可容纳600个座,位于西看台二层前排正中处。西看台对准100米跑道终点处设裁判席,其左侧设300个座位的记者席。在南看台顶部设有一座35米×12米的大型彩色电子显示屏幕,供比赛时记时记分显示图像用。
    在比赛场地四周的底层看台下空间,设有运动员、裁判员专用的竞技技术用房,按国际比赛要求分设赛前准备,赛后控制中心等设施。
    为适应体育事业产业化改革的发展,在第一层看台后排及第一层与第二层看台之间的夹层空间设置100间包箱,每间包箱拥有宽敞的休息室,可俯视全场,并带有18个席位的专座。
    在充分利用看台下的有效空间,提高多功能综合使用方面进行了精心设计。如利用西看台端部蕴藏了一栋九层高的星级旅馆,在看台顶层设有空中咖啡厅,可以俯视球场全景,此外还有24间客房,也可在客房内直接俯视比赛场景,这是在大型体育场设计中首次尝试。
    在东看台下部空间,建造一座水上娱乐城,有宽敞的沙滩游泳场、冲浪漂流池以及水上剧场,可举行海豚表演、水上音乐会等娱乐活动,整个水面达8000平方米左右,此外还配备各种健身、娱乐、休闲的设施,向公众开放。 在南、北看台的底层还有展览厅、商场、会议新闻中心等多功能使用。整个体育场建筑面积达17万平方米。
    体育场造型简洁,完整有力,立面造型虚实结合,以实体玻璃墙与周围缕空的构架结构形成对比,高低起伏的马鞍形白色透明的膜结构屋顶,在阳光照射下,犹如一圈璀灿的光环,一片飘逸的白云,腾空升华在上海市的上空。
steelxu
积分 26
帖子 12
2002-1-8 22:00    顶部
上海体育场(SHANGHAI SPORTS CENTRE)是一座建筑造型新颖、马鞍型可容纳八万名观众的体育场(见照片1、2)。集体育竞技、文体表演、宾馆住宿、健身娱乐、购物展览、商业餐饮于一体,总共建筑面积为17万平方米,是97年召开的中国第八届全国运动会的主赛场。体育场屋盖是一个马鞍型,由径向悬挑桁架加环向桁架组成的环状大悬挑钢管空间结构。屋面层为57个伞状拉索结构,上面覆盖高技术材料(SHEERFILL)膜层。屋面平面投影呈椭圆型,东西宽288.4m,南北长274.4m,中间开东西宽150m,南北长213m椭圆孔。屋盖檐口高度:西部:62.5m、东部:41.2m、南北部:31.8m;屋盖悬挑长度:西部73.5m、东部46m、南北部22.9m。屋盖水平投影面积37000m2超过1996年美国Atlanta奥运会GEORGIA DOME膜结构(长轴230m,短轴183m,水平投影面积33000m2)。屋盖最大悬挑长度为73.5m,超过意大利罗马Olympic Stadium膜结构(悬挑长度63m左右)。
steelxu
积分 26
帖子 12
2002-1-8 22:08    顶部
照片2
zjwrh
积分 21
帖子 18
2008-2-29 11:00    QQ 顶部
这里有几张照片,大家可以看看,希望有更多的关于结构部分的详图照片
http://www.hoodong.com/wiki/%E4% ... 3%E8%82%B2%E5%9C%BA
大朴胜华
积分 31
帖子 37
2008-2-29 21:37    QQ 顶部
感觉比鸟巢好看。有规律,不混乱。
yan860914
积分 14
帖子 18
2008-12-23 10:33    QQ 顶部
挺漂亮的,两种都很喜欢
wendi
积分 38
帖子 32
2009-1-6 23:21    顶部
有没有08年初该体育场膜破坏的图片,现在已经修好了吗?
