求解三角形管桁架SAP2000模型问题
sifone
请各位帮我看看这个模型运行出现负的周期是什么原因,如何解决,谢谢!
* * * W A R N I N G * * *
ZERO OR NEGATIVE MODAL-MASS VALUES WERE DETECTED DURING ITERATION,
THE RESULTING EIGEN-MODES MAY NOT BE VALID - CHECK THEM CAREFULLY !!
THE STRUCTURE IS UNSTABLE OR ILL-CONDITIONED !!
CHECK THE STRUCTURE CAREFULLY FOR:
- INADEQUATE SUPPORT CONDITIONS, OR
- ONE OR MORE INTERNAL MECHANISMS, OR
- ZERO OR NEGATIVE STIFFNESS PROPERTIES, OR
- EXTREMELY LARGE STIFFNESS PROPERTIES, OR
- BUCKLING DUE TO P-DELTA OR GEOMETRIC NONLINEARITY, OR
- A FREQUENCY SHIFT (IF ANY) ONTO A NATURAL FREQUENCY
NUMBER OF EIGEN MODES FOUND = 3
NUMBER OF ITERATIONS PERFORMED = 7
NUMBER OF STIFFNESS SHIFTS = 0
[管桁架模型]
GHJ2_V9_V11.rar ( 22.11 K)
下载次数 77
橘子天空
2013-4-27 16:49
没有啊,我这边运行是正常的。好像周期是0.38
zhuyulin10
2013-8-8 13:23
没问题,我用sap2000 14打开的。还进行了杆件设计选型。
