A double layer membrane structure
hhux2002
A double layer membrane structure with insulation between the layers as the roof for a hotel lobby area was constructed recently.
The membrane is supported on the frame which consist of side beam, gutter beam, perimeter column and diagonal member below the beams and 2 nos of internal column and a girder frame.
The outer fabric consist of 12 nos of cones. The projection area of outer fabric is about 44 X 31 metres. Underneath the outer fabric is the inner fabric, it is having only 8 nos of cone with a projection area 22 X 24 metres.
Material:
a fiber glass coated PTFE is used as a
bearing structure
Code:
Steel structure BS5950, Wind load CP3
Material test BS3424, BS7304, BS342, BS476
Software:
EASY
zyqzzz
(点点)
2001-12-4 10:37
我们正在做一个外膜65.8*30.2,内膜54.6*23.4的双层膜工程,能否交流一下(私下的),我不会随意散布的。ok?
